CONVG
Bulk Data Entry Defines Free convection via automatic generation of free convection entries. This entry also supports subcase-dependent free convection.
| CONVG | ID | TYPE | SID | SIDE | TEMP_AMB | HTC | TID_HTEMP | TID_HTIME | |
| + | TID_AMB |
| CONVG | 12 | ELEM | 21 | 1 | 20.0 | 30.0 |
| ID | Unique identification
number. No default (Integer > 0) |
| TYPE | Entity used to identify
Convection surfaces.
No default |
| SID | If TYPE
field is set to ELEM, SID
represents an element ID. If TYPE field is set to SURF, SID represents a SURF ID. If TYPE field is set to PROP, SID represents a PROP ID of a PSOLID Bulk Data Entry. No default (Integer > 0) |
| SIDE | If TYPE
field is set to ELEM, then SIDE
represents the Element Side identification number. 5 It is mandatory to define the element side ID
if TYPE field is set to
ELEM. Default = blank (Integer) |
| TEMPAMB | Ambient point temperature.
Default = 0.0 (Real > 0.0) |
| HTC | Free convection Heat
Transfer Coefficient. Default = 0.0 (Real) |
| TID_HTEMP | Temperature-dependent Heat
Transfer Coefficient defined via TABLEMi or
TABLEMGi Bulk Data Entries. Default = Blank (Integer > 0) |
| TID_HTIME | Time-dependent Heat
Transfer Coefficient defined via a TABLEDi Bulk
Data Entry. Default = Blank (Integer > 0) |
| TID_AMB | Time-dependent Ambient
point temperature defined via a TABLEDi Bulk Data
- The CONVG Bulk Data is an automatic method to define a free convection setup. The free convection entries such as CHBDYE, PCONV, CONV, SPC, and any corresponding GRID entries are automatically generated internally. PARAM, CONVG, YES can be used to output a separate *_CONVG.fem file which contains the internally generated entries coming from CONVG.
- The CONVG Bulk Data Entry is
supported for the following solutions:
- Linear Steady-state Heat Transfer
- Linear Transient Heat Transfer
- Nonlinear Steady-state Heat Transfer
- Nonlinear Transient Heat Transfer
- Defining free convection in a Forced convection analysis via Darcy flow.
- The CONVG Bulk Data should be referenced by a corresponding CONVG Subcase Information Entry.
- Multiple CONVG Bulk Data Entries can be referenced on a CNVGADD Bulk Data Entry.
- Refer to comments on the CHBDYE Bulk Data Entry for Element Side identification numbers.
- Topology optimization is supported for linear steady-state heat transfer analysis with TYPE = PROP. Defining TYPE = PROP allows the convection boundary to be dynamically updated during the topology optimization process. This capability is currently only supported for a linear steady-state heat transfer analysis and for solid elements (TETRA, TET10, HEXA, HEXA20, PENTA, PEN15, PYRA, PYRA13).
