QBDY1
Bulk Data Entry Defines a uniform heat flux for CHBDYE elements.
QBDY1 | SID | Q0 | EID1 | EID2 | EID3 | EID4 | EID5 | EID6 |
Alternate Format
QBDY1 | SID | Q0 | EID1 | "THRU" | EID2 |
SID | Load
set identification number. No default (Integer > 0) |
Q0 | Heat
flux into element. Is positive for heat
input. No default (Real) |
EID# | CHBDYE surface element identification
numbers. With alternate format using "THRU" EID2
> EID1. No default (Integer ≠ 0) |
- QBDY1
entries must be selected with the Case Control command
LOAD=SID in order to be used in static analysis. The
total power into an element is given by the equation: Pin=(Effective_Area)*Q0
- This card is represented as a flux load in HyperMesh.
