Linear Transient Heat Transfer Analysis
Calculates the temperature distribution in a system with respect to time.
The applied thermal loads can either be time-dependent or time-invariant; transient thermal analysis is used to capture the thermal behavior of a system over a specific period of time.
The basic finite element equation for transient heat transfer analysis is given by:
- Heat capacity matrix
 - Conductivity matrix
 - Boundary convection matrix due to free convection
 - Derivative of the nodal temperature matrix with respect to time
 - The unknown nodal temperature matrix
 - Thermal loading vector
Thermal load vector can be expressed as:
- Power due to heat flux at boundary specified by QBDY1 card.
 - Boundary convection vector due to convection specified by CONV card.
 - Power vector due to internal heat generation specified by QVOL card.
The differential equation is solved to find nodal temperature at the specified time steps. The difference between the equation and the Linear Steady-State Heat Transfer Analysis equation is the term, , that captures the transient nature of the analysis.
