Save as
Save As and Save functions:
In Script Factory application, an edited python file can be saved with a new name (Save
            As function) or with the same name (Save function).
| How to “Save As” a python Script ? | |
| 1 | Click on the dropdown menu select the function “Save As” |
| 2 | Click on the function “Save As” via the dropdown menu. |
| 3 | Give a name to the python script you want to save. |
| 4 | Select a working folder to store the new file (The default one is the current workspace). |
| 5 | A python file can be saved with the same name with the “Save” function. |
Note:
- To “Save” a file you can also use the classical shortcut keyboard “Ctrl+S”
- To “Save as” a file you can also use the classical shortcut keyboard “Ctrl+E”
