NVH - Working point - If.I.PSI.N
1. Positioning and objective
The aim of the test “Mechanics – NVH – Working point – If-I-Ψ-N” is to perform NVH
                analysis of the machine when operating at the targeted working point defined with
                the following inputs values If,I,Ψ,N (Magnitude of field current, magnitude of
                current, Control angle, Speed).
| “Working point – Sine wave – Motor – If, I, Ψ, N” illustrat |
This test give data allowing NVH prediction in early electromagnetic and design stage.
The modal analysis of the stator mechanical structure, the radiated sound power and the magnetic forces applied on teeth are computed and displayed.
This test helps to answer the following question:
- Could the machine have any risks in connection with NVH? Yes / No.
The following table helps to classify the test “Mechanics – NVH – Working point –If-I-Ψ-N”.
| Family | Mechanics |
| Package | NVH |
| Convention | # |
| Test | Working point - If-I-Ψ- N |
| Positioning of the test “Mechanics – NVH – Working point – If-I-Ψ-N” | |
2. User inputs
The three main user input parameters are the supplied line current, the control angle and the speed. In addition, temperatures of winding and magnets must be set.
3. Main outputs
Test results are illustrated with data, graph and tables.
                    Tables of results - Machine performance - Working point defined with If-I-Ψ-N
                    Graphs, curve and maps to illustrate NVH analysis results - Modal analysis
- Radiation efficiency
- Space-Time normal flux density in the airgap
- Space-Time Maxwell pressure
- Radiated sound power
- Electromagnetic forces on teeth
