All machines
Distribution of computations cannot be used for computing NVH spectrogram
(ref.: SLVFXM-15772) - This issue has been corrected.
Computation of maps may be incompatible with the Flux distribution mode
It is highly recommended to not use the Flux distribution mode while computing maps.
This restriction must be applied for the test Characterization / Model / maps test as well as for the export of maps to System (ref.: SLVFXM-17954).
Import input function doesn’t work
In the Export / HyperStudy area, the import input function doesn’t work for thermal settings (ref.: SLVFXM-17724).
Issue with the number of decimals after dot
When setting the common user preferences "No. decimal after dot" equal to 5, the numbers less than 1 written with an exponent (1E-X) become equal to 0 (ref.: SLVFXM-17837 + SLVFXM-17838).
These issues have been corrected.
Export LUT – Issue with the temperature dependency of the stator resistance
While exporting the LUT, the value of the stator resistance doesn’t consider the temperature, which is defined in the thermal settings (ref.: SLVFXM-17692).
Null values are not well managed while designing the Frame and shaft.
Null values are allowed for designing the housing, bearing, or shaft dimensions, but this leads to the wrong thermal analysis. It is highly recommended not to use null values for the inputs considered (ref.: SLVFXM-14705).
This issue has been corrected. Null values are now forbidden.
Export to FeMT with too long output path
The Flux script crashes when the output path for FeMT export is too long (ref.: SLVFXM-15471).
Fault in the coupling FluxMotor-HyperStudy
An error in the FluxMotor process doesn't stop the HyperStudy execution (ref.: SLVFXM-15402).
Issue with exported Flux Skew projects
After exporting a Flux Skew project, if the user solves the project, deletes the results, and then solves them again, the running of the project fails (ref.: SLVFXM-15075).
Error while opening a motor (2020.1) with null shaft extension.
Opening a motor built with version 2020.1 (or older) with a null shaft extension leads to an error. With new versions, a null shaft extension is forbidden (ref.: SLVFXM-14684).
Power electronics and coupling with HyperStudy®
For tests where the setting "Electronics" is available, data like power electronics stage, maximum efficiency, and its rated power can be selected for generating a connector for HyperStudy®, but it should not be.
In the Export-HyperStudy® area, when the selected test is “Working Point, T-N”, the settings of “Electronics” - "Max efficiency", and "Rated Power" - are exported even if the associated option is not selected (ref.: SLVFXM-13726).
