Induction machines – Motor Factory – Test environment
The computation of the efficiency map (U, I) with mechanical losses can fail
This issue raises a null-pointer exception (ref.: SLVFXM-16157).
This issue has been corrected.
Error when exporting and solving a project in Flux Skew – Transient application
This issue occurs when the user input “Represented coil conductors” is set to All phases (ref.: SLVFXM-15877).
Power balance of No-load working point
Sometimes, computation of the no-load working point (slip = 0.1%) leads to a NaN (Not a Number) result. The computed amount of iron losses is not consistent with the power balance (ref.: SLVFXM-12600).
Issue while computing the efficiency map (scalar control – U,f or U,I) – IMSQ
The scalar model gives wrong results when hairpin winding technology is considered compared to results obtained with an equivalent classical winding (ref.: SLVFXM-17183).
