Introduction
The total number of user inputs is equal to 15 for a machine without skew and 16 for a skewed machine.
Among these inputs, 8 are standard inputs and 8 or 7 are advanced inputs, depending on whether a machine is skewed or not.
Standard inputs
Convention
There are two conventions to choose from: “generator” and “motor”.
The “generator” convention is considered the default. In this convention, the machine operates as a generator from an electrical perspective. It receives mechanical power through the shaft (input) and outputs electrical power via the stator winding.
Operating mode
There are two operating modes to choose from: “generator” and “motor”.
Power definition mode
Output power
If the generator operating mode is selected, the output power corresponds to the machine's active power, labeled “Stator Electrical Power” in the “Machine Performance – Working Point” result table.
- Same Convention and Operating Mode (either motor or generator):- Power output is a positive value.
-  Mixed Convention and Operating Mode (motor convention with generator
                            operating mode, or generator convention with motor operating mode):- Power output is a negative value.
If an incorrect value is entered, an error message will appear when the user clicks the "Run" button.
Apparent power
Power factor definition mode
The power factor itself is not sufficient to determine if a machine supplies or consumes reactive power from the electrical network. Therefore, the user is provided with two options for the power factor.
The power factor lag means that the phase current vector is behind the phase voltage vector and the reactive power is positive, or the machine supplies reactive power in the generator convention and consumes reactive power in the motor convention.
The power factor lead means that the phase current vector is in advance compared to the phase voltage vector and the reactive power is negative, or the machine consumes reactive power in the generator convention and supplies reactive power in the motor convention.
Power factor lag
- Same Convention and Operating Mode (either motor or generator):- Power factor lag varies between 0 and 1.
                            operating mode, or generator convention with motor operating mode):- Power factor lag varies between -1 and 0.
Power factor lead
- Same Convention and Operating Mode (either motor or generator):- “Power factor lead” varies between 0 and 1.
                            operating mode, or generator convention with motor operating mode):- “Power factor lead” varies between -1 and 0.
Field current definition mode
In the backend of FluxMotor, machine performance is analyzed within a research zone defined by the field current and the control angle. The goal is to identify the combination of field current and control angle that allows achieving the desired working point characterized by P-Pf-U-N. The maximum field current sets the upper limit for the field current.
- by the current density in electric conductors, in this case, the field current definition mode should be « Density ».
- by indicating the value of the field current (DC value), in this case, the field current definition mode should be « Current ».
Maximum Field current
When the choice of current definition mode is “Current”, the DC value of the maximum current supplied to the field winding: “Maximum Field current” (Current in Field conductors), must be provided.
Maximum Field current density
Speed
The imposed “Speed” (Speed) of the machine must be set.
Line-line voltage, rms
The imposed “Line-line voltage” (Line-line voltage, rms) of the machine must be set.
Ripple torque analysis
The “Ripple torque analysis” (Additional analysis on ripple torque period: Yes / No) allows to compute or not the value of the ripple torque and to display the corresponding torque versus the angular position over the ripple torque period.
                            • This choice influences the accuracy of results and the computation time. The magnitude of the ripple torque is calculated. This additional computation needs additional computation time.
- In the case of “Yes”, the ripple torque is computed. Then, the flux density in regions is evaluated through the ripple torque computation
- In the case of “No”, the ripple torque is not computed.
Then, the flux density in regions is evaluated by considering the Park’s model computation.
Advanced inputs
Number of computations for Jd, Jq per quadrant
Number of computations for field current
In the backend of FluxMotor, the field current is varied within a research zone from 0 to the maximum field current defined previously to find the value allows achieving the desired working point P-Pf-U-N. This research zone is discretized linearly based on the “Number of computations for field current.”
If higher accuracy is needed, increase this value accordingly, keeping in mind that higher values will require more computing time.
Number of computations for control angle
Considering the vector diagram shown below, the “Control angle” is the angle between the electromotive force (E) and the electrical current (J) (Ψ= angle (E, J)).
| Definition of the control angle Ψ |
In the backend of FluxMotor, the control angle is varied within a research zone to find the value allows achieving the desired working point P-Pf-U-N. This research zone is discretized linearly based on the “Number of computations for control angle.”
Number of computations per ripple torque period
The number of computations per ripple torque period is considered when the user has chosen to perform a “Ripple torque analysis” (i.e., answered “Yes” to the standard input “Ripple torque analysis” required only with “Fast” computation mode).
The user input “No. comp. / ripple period” (Number of computations per ripple torque period) influences the accuracy of the results (computation of the peak-peak ripple torque) and the computation time.
The default value is equal to 30. The minimum allowed value is 25. The default value provides a good balance between the accuracy of results and computation time.
| Definition of the number of computations per ripple torque period |
Skew model – Number of layers
When the rotor magnets or the armature slots are skewed, the number of layers used in Flux® Skew environment to model the machine can be modified: “Skew model - No. of layers” (Number of layers for modeling the skewing in Flux® Skew environment).
Rotor initial position
By default, the “Rotor initial position” is set to “Auto”.
When the “Rotor initial position mode” is set to “Auto”, the initial position of the rotor is automatically defined by an internal process of FluxMotor®. The resulting relative angular position corresponds to the alignment between the axis of armature phase 1 (reference phase) and the direct axis of the salient pole.
When the “Rotor initial position” is set to “User input” (i.e., the toggle button on the right), the initial position of the rotor to be considered for computation must be set by the user in the field « Rotor initial position ». The default value is equal to 0. The range of possible values is [-360, 360]. For more details, please refer to the document: MotorFactory_SMWF_ISP_IR_3PH_Test_Introduction – section “Rotor and armature relative position”.
Mesh order
To get the results, the original computation is performed using a Finite Element Modeling.
By default, a second order mesh is used.
Airgap mesh coefficient
The advanced user input “Airgap mesh coefficient” is a coefficient that adjusts the size of mesh elements inside the airgap. When the value of the “Airgap mesh coefficient” decreases, the mesh elements get smaller, leading to a higher mesh density inside the airgap and increasing the computation accuracy.
The imposed Mesh Point (size of mesh elements touching the points of the geometry) inside the Flux® software is described as:
Mesh Point = (airgap) x (airgap mesh coefficient)
