Standard inputs
                    Line-line voltage, rms The line-line voltage supplied to the machine: “Line-line voltage, rms” ( Line-line voltage, rms value ) must be provided.
                    Slip or Speed mode There are two usual parameters to define the working point. It can be defined by the slip “ Slip ” or by the mechanical speed “ Speed ”.
                    Slip If the “Definition mode” is “ Slip ”, the value of the machine’s slip must be provided, and the corresponding speed is deduced. The slip “s” in the following relations) corresponds to the relative difference between the synchronous speed (N Synch. ) and rotor speed N:
                    Speed If the “Definition mode” is “ Speed ”, the targeted rotor speed must be provided, and the resulting slip is deduced.
                    Power supply frequency The power supply frequency corresponds to the electrical frequency of the stator magnetic field.
Advanced inputs
The lists of advanced inputs dedicated to this export are listed below.
For more details please refer to the list of generic advanced inputs.
- Rotor initial position
                    Mesh order The default level is second order mesh.
                    Airgap mesh coefficient Airgap mesh coefficient is set to 1.5 by default.
