Standard inputs ––––--
Current definition mode
There are 2 common ways to define the electrical current.
In this case, the current definition mode should be « Density ».
Electrical current can be defined directly by indicating the value of the line current (the RMS value is required).
In this case, the current definition mode should be « Current ».
Max. field current
When the choice of field current definition mode is “Current”, the maximum DC value of the field current supplied to the machine “Max. field current” (Maximum field current) must be provided.
Note: The number of parallel paths is automatically considered in the results.
Max. field current density
When the choice of field current definition mode is “Density”, the maximum DC value of the current density in electric conductors “Max. field current density” (Maximum current density) must be provided.
Max. line current, h1 rms
When the choice of current definition mode is “Current”, the maximum rms value of the line current supplied to the machine “Max. line current, h1 rms” (Maximum line current, first harmonic rms value) must be provided.
Note: The number of parallel paths and the winding connections are automatically considered in the results.
Max. current dens. h1, rms
When the choice of current definition mode is “Density”, the maximum rms value of the current density in electric conductors “Max. current dens., h1 rms” (Maximum current density in conductors, first harmonic rms value) must be provided.
Note: The number of parallel paths and the winding connection are automatically considered in the results.
Max. Line-Line voltage, h1 rms
To supply the machine the rms value of the maximum Line-Line voltage: “Max. Line-Line voltage, h1 rms” (Maximum Line-Line voltage, first harmonic rms value) must be provided.
Command mode
One command is available: Maximum Torque Per Voltage (MTPV) command mode.
The base speed point corresponds to the working point which maximizes the mechanical torque at maximum current and at maximum voltage.
Note: The computed maximum speed depends on the chosen command mode.
Maximum speed
The computation and analysis of the torque-speed curves are performed over a given speed range.
The maximum allowed value for the « Maximum speed » corresponds to 53000 rad/s - about 506000 rpm.
Note: As a function of the maximum speed value, following different cases must be considered:
  1. Case 1: The maximum speed is lower than the base speed Nbase (corner point speed of the torque-speed curve) Nmax < Nbase.
    In that case, for any command mode (MTPA or MTPV), the behavior of the machine will be studied over the speed range [0, Nmax].
    That allows the user to precisely choose the range of speed to be considered for computing and displaying the torque-speed curve and especially maps like efficiency map.
  2. Case 2: The maximum speed is greater than the base speed (corner point speed) Nmax > Nbase.
    The relevance of the maximum speed given by the user is analyzed to evaluate if it is reachable by the machine.
    If the user maximum speed is unreachable by the machine, the correction of this value is automatically performed.
The resulting new maximum speed is linked to a limit torque. This limit torque is obtained by applying a reduction coefficient to the base point torque.
Rotor position dependency
It defines the rotor position dependency of electromagnetic data used for the optimization of the efficiency map such as D-axis magnetic flux, Q-axis magnetic flux, electromagnetic torque, iron losses. By default, the rotor position dependency is set to “No” but it can be set to “Yes”. In this case the computation will be done along the three dimensions Jd – Jq – If, with an additional fourth axis corresponding to the rotor position θr.
Note: This option allows to have a better accuracy in the evaluation of magnetic flux, electromagnetic torque as well as iron losses. It is worth noting that only with rotor position dependency that the rotor iron losses can be evaluated.
User working point(s) analysis
It is possible to perform additional analysis on working point(s) located under the torque-speed curve. The user’s input “User working point(s) analysis” (additional analysis on working point(s)) gives three possibilities to the user:
  1. User working point(s) analysis = None (=default mode)
    This corresponds to the basic configuration of the test, with no additional working point analysis.
  2. User working point(s) analysis = Single point
    This allows computing the machine performance on a working point specified by the user with the targeted speed and torque. In that case the next two fields must be filled with the targeted speed and mechanical torque.
    Table 1. User working point analysis = Single point
    1 Select the “Single point” option to perform a computation on one working point.
    2-3 Define the targeted working point mechanical torque and speed.
  3. User working point(s) analysis = Duty cycle
    This allows computing the machine performance all over a considered duty cycle.
    This duty cycle must be defined by using the next field: "Duty cycle description" and by clicking on the button "Set values".
    Two ways are possible to fill in the table: either filling in the table line by line or by importing an excel file which all the working points of the duty cycle are defined.
    Note: A working point is defined by a time, a speed, and a mechanical torque.
Table 2. User working point analysis = Duty cycle
1 Select the “Duty cycle” option.
2 Click in the button “Set values” of the field “Duty cycle” to open a dialog box to define the duty cycle.
Refer to the next illustration which shows how to fill the Duty cycle table.
1.1 Dialog box opened after having clicked on the button “Set values” in the field “Cycle description”
1.2 Browse the folder to select an Excel file which describes the duty cycle.
1.3 Button to refresh the table data when the considered Excel file has been modified.
1.4 Fields to be filled with data to describe the duty cycle to be considered.
1.5 Excel file template to define the duty cycle
Note: Once the test results have been computed, new user working point and duty cycle values can be set, and results will appear instantaneously when relaunching the test.
Note: A working point is defined by a time, a speed, and a mechanical torque. The time must always begin by 0 second.
Note: The Excel template used to import a duty cycle is stored in the folder Resource/Template in the installation folder of FluxMotor®. An example of this template is displayed below.
Advanced inputs ––––--
No. computed elec. periods
The user input “No. computed elec. periods” (Number of computed electrical periods only required with rotor position dependency set to “Yes”) influences the computation time of the results.
The default value is equal to 0.5. The maximum allowed value is 1, according to the fact that computation is done to characterize steady state behavior based on magnetostatic finite element computation. The default value provides a good compromise between the accuracy of results and computation time.
Note: The outcomes obtained at 0.5 or 1 electrical period are identical across all presented outputs, except for slight variations in rotor iron losses arising from the symmetrical assumption regarding the magnetic flux waveform on the rotor.
No. comp / elec. period
The user input “No. comp / elec. period” (Number of computations per electrical period required only with “Accurate” computation mode or “Fast” computation mode with rotor position dependency activated) influences the accuracy of results (computation of the peak-peak ripple torque, iron losses, AC losses…) and the computation time.
The default value is equal to 40. The minimum recommended value is 20. The default value provides a good balance between accuracy of results and computation time.
No. comp. for Jd,Jq
To get maps in the Jd-Jq plan, a grid is defined. The number of computation points along the d-axis and q-axis can be defined with the user input « No. comp. for current Jd, Jq » (Number of computations per quadrant for D-axis and Q-axis phase currents).
The default value is equal to 6. This default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 5.
Note: As a synchronous machine with wound field machine operates in both 1st and 2nd quadrants, the total number of computations for the D-axis is twice the number entered for « No. Comp. for Jd, Jq » minus one as the zero value is shared between the two quadrants. For example, if « No. Comp. for Jd, Jq » is 6, there will be 11 computations for the D-axis.
No. comp. for If
First, it is needed to compute the D-axis and Q-axis flux linkage in the Jd - Jq planes at various levels of If.
To get D-axis and Q-axis flux linkage maps along If dimension, the field current is discretized from zero to its maximum value. The number of computation points along the If-axis can be defined with the user input « No. comp. for If » (Number of computations for If-axis field currents).
No. comp. for speed
The “No. comp. for speed” (Number of computations for speed) corresponds to the number of points to be considered in the speed range from 0 to the maximum speed.
Half of these points are distributed from 0 to the base speed. The remaining points are distributed from the base speed to the maximum speed.
In both cases, base speed is considered as an additional point.
Note: If the user input parameter “No. comp. for speed” is an odd number, one discretization point is automatically removed.
Figure 1. Definition of the number of computations for speed
The default value is equal to 15, the minimum allowed value is 5. The maximum recommended value is 40.
Note: Increasing the number of computations can improve the convergence of the optimization used to define the torque-speed curve and the efficiency map. However, that also means longer computation time.
No. comp. for torque
For the speed range [Nbase; Nmax.], the number of computations for torque is imposed by the number of computations for speed in the speed range [Nbase; Nmax.] (Red points in the image shown below).
The advanced user input parameter “No. comp. for torque” allows to finalize the grid within the torque range [0, T (Nmax.)] at the maximum speed (Black points in the image shown below).
The default value is equal to 7. The minimum allowed value is 3. The maximum recommended value is 20.
Figure 2. Definition of the number of computations for torque – MTPV command mode
Skew model – No. of layers
When the rotor magnets or the stator slots are skewed, the number of layers used in Altair Flux Skew environment to model the machine can be modified: “Skew model - No. of layers” (Number of layers for modelling the skewing in Flux Skew environment).
Note: When there is magnet step skew topology, the number of layers is defined at the design level.
Rotor initial position
By default, the “Rotor initial position” is set to “Auto”.
When the “Rotor initial position mode” is set to “Auto”, the initial position of the rotor is automatically defined by an internal process.
The resulting relative angular position corresponds to the alignment between the axis of the stator phase 1 (reference phase) and the direct axis of the rotor.
When the “Rotor initial position” is set to “User input” (i.e. toggle button on the right), the initial position of the rotor considered for computation must be set by the user in the field « Rotor initial position ». The default value is equal to 0. The range of possible values is [-360, 360].
Notice: The computations are performed by considering the relative angular position between the rotor and stator.
This relative angular position corresponds to the angular distance between the direct axis of the rotor north pole and the axis of the stator phase 1 (reference phase).
The value of the rotor D-axis location, which is automatically defined for each saliency part.
Below is illustrated the Rotor and stator phase relative position
The relative angular position between the axis of the stator phase 1 (reference phase) and the rotor D-axis position must be controlled to perform the tests. See the picture below which will allow defining the working point of the machine.
Figure 3. Definition of rotor initial position – Rules for direction
The winding axis of the reference phase is defined from the phase shift of the first electrical harmonic of the magneto motive force (M.M.F.).
Mesh order
To get the results, Finite Element Modelling computations are performed.
The geometry of the machine is meshed.
Two levels of meshing can be considered: First order and second order.
Airgap mesh coefficient
The advanced user input “Airgap mesh coefficient” is a coefficient which adjusts the size of mesh elements inside the airgap. When the value of “Airgap mesh coefficient” decreases, the mesh elements get smaller, leading to a higher mesh density inside the airgap, increasing the computation accuracy.
The imposed Mesh Point (size of mesh elements touching points of the geometry), inside the Altair Flux software, is described as:
MeshPoint = (airgap) x (airgap mesh coefficient)
0.05 giving a very high mesh density and 2 giving a very coarse mesh density.
CAUTION: Be aware, a very high mesh density does not always mean a better result quality. However, this always leads to a huge number of nodes in the corresponding finite element model. So, it means a need for huge numerical memory and increases the computation time considerably.
The impact of the airgap mesh coefficient on resultant meshing is illustrated bellow:
