Standard inputs ––––--
Current definition mode
There are 2 common ways to define the electrical current.
In this case, the current definition mode should be « Density ».
Electrical current can be defined directly by indicating the value of the line current (the RMS value is required).
In this case, the current definition mode should be « Current ».
Max. field current density
Max. field current
Speed
Back emf target point
The main principle of the No-load test is to perform successive Back EMF tests for different values of field current, to extract a Back-EMF versus the field current curve. However, the full results of those Back EMF tests are not displayed.
This input allows the user to indicate if a full Back-EMF test, and its results, should be presented in the output section. The default option is “No”.
Field current
When the choice of current definition mode is “Current”, the DC value of the current supplied to the field winding: “Field current” (Current in Field conductors) must be provided.
Field current density
If the “Back EMF target point” is set to “Yes”, the user must provide a field current point in which will be perform the Back-EMF test.
The default value is the same as the “Maximum field current density” input.
Advanced inputs ––––--
No. comp. for if
- Computation of the back-EMF:
To compute the Back-EMF for different magnetization states, the field current If is discretized from zero to its maximum value.
The number of computation points for the If discretization can be defined with the user input « No. comp. for If » (Number of computations for field current).
The default value is equal to 6. This default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 5.
- Computation of maps in Jd,Jq plan:
To get maps along the If dimension, the field current is discretized from zero to its maximum value. The number of computation points along the If - axis can be defined with the user input « No. comp. for If » (Number of computations for If - axis field currents).
The default value is equal to 6. This default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 5.Note: If one uses more than one quadrant, the total number of computations for Jd and Jq will be calculated based on the No. comp. for current Jd, Jq input and the number of quadrants. For example, if No. comp. for current Jd, Jq is set to 10 and the quadrant is set to “1st and 2nd “, then the total number of computations for Jd is 10, but 19 for Jq considering Jd = 0 is shared between both quadrants
No. comp. / elec. period
The number of computations per electrical period “No. comp. / elec. period” (Number of computations per electrical period) influences the accuracy of results and the computation time.
Maximum harmonic order
To get the Back-EMF versus time, the flux through each phase of the machine is computed versus rotor angular position.
Harmonics are extracted from the frequency analysis (F.F.T. Fast Fourier Transform) of the Back-EMF signal versus time.
The default value is equal to 20. The minimum allowed value is 1.
Rotor initial position
By default, the “Rotor initial position” is set to “Auto”.
When the “Rotor initial position mode” is set to “Auto”, the initial position of the rotor is automatically defined by an internal process.
The resulting relative angular position corresponds to the alignment between the axis of the stator phase 1 (reference phase) and the direct axis of the rotor.
When the “Rotor initial position” is set to “User input” (i.e. toggle button on the right), the initial position of the rotor considered for computation must be set by the user in the field « Rotor initial position ». The default value is equal to 0. The range of possible values is [-360, 360].
Notice: The computations are performed by considering the relative angular position between the rotor and stator.
This relative angular position corresponds to the angular distance between the direct axis of the rotor north pole and the axis of the stator phase 1 (reference phase).
The value of the rotor D-axis location, which is automatically defined for each saliency part.
Below is illustrated the Rotor and stator phase relative position
The relative angular position between the axis of the stator phase 1 (reference phase) and the rotor D-axis position must be controlled to perform the tests. See the picture below which will allow defining the working point of the machine.
The winding axis of the reference phase is defined from the phase shift of the first electrical harmonic of the magneto motive force (M.M.F.).
Skew model – No. of layers
Mesh order
To get the results, Finite Element Modelling computations are performed.
The geometry of the machine is meshed.
Two levels of meshing can be considered: First order and second order.
Airgap mesh coefficient
The advanced user input “Airgap mesh coefficient” is a coefficient which adjusts the size of mesh elements inside the airgap. When the value of “Airgap mesh coefficient” decreases, the mesh elements get smaller, leading to a higher mesh density inside the airgap, increasing the computation accuracy.
The imposed Mesh Point (size of mesh elements touching points of the geometry), inside the Altair Flux software, is described as:
MeshPoint = (airgap) x (airgap mesh coefficient)
The impact of the airgap mesh coefficient on resultant meshing is illustrated bellow:
