Damper
Illustration
The rotor of a wound field synchronous machine is very often composed of a magnetic circuit with a damper included inside.
The damper is designed with bars that are short-circuited by end-ring on both sides - Connection Side (C.S.) and Opposite Connection Side (O.C.S.). The end-rings can be designed with full rings or with sectors on each pole.
Figure 1. Wound field synchronous machine with damper – Rotor – Magnetic circuit and damper with full end-rings
Figure 2. Damper of a wound field synchronous machine built with full rings on both sides - Damper (1) = Bars (2) + Full end-rings (3)
Figure 3. Wound field synchronous machine with damper – Rotor – Magnetic circuit and damper with end-ring sectors
Figure 4. Damper of a wound field synchronous machine built with end-ring sectors on both sides - Damper (1) = Bars (2) + End-ring sectors (3)
Bars - General information
When needed, the design of the damper bars (number, position and dimensions) is done in the part Pole (Pole shoe) and they can be parameterized as well.
It is why there is not a dedicated area in the Motor Factory design area to change the shape of bars only. To change the number and the shape of bars, one must change the whole pole topology (Pole shape in the Motor Factory – design area).
Overview
In Motor Factory – Design area, the environment “Damper” allows the design of the cross-section shape and the dimensions of the damper end-rings on both sides of the machine.
Note: The context is disabled if there is no bar (no solid conductor) in the pole topology.
The type of end-ring can also be defined as a full ring or end-ring sectors.
A section scrolling bar allows choosing the section in which user inputs are defined.
Scrolling selection bar where Design, Impedance, X-Factor and Operating conditions sections can be selected.
Table 1. Damper design area
1 Selection of the Damper panel (Click on the Damper icon)
Several sections allow defining all characteristics that deal with the end-ring: Design, Impedance, X-Factor and Operating.
2 Access to the section dedicated to the design of the end-rings.
Note: By default, the section Design is selected.
2.1 The type of end-ring can be defined as a full ring or end-ring sectors.
2.2 User inputs dedicated to the design of the slot.
3 Impedance tab gives the tools to compute the inter-bar impedance of the squirrel cage.
4 X-Factor tab gives access to the user coefficients (calibration factors = X-factors) that allows to tune the inter-bar end-ring resistances and inductances.
5 Operating tab to define a working point for evaluating the characteristics of the inter-bar end-ring impedances.
Note: Since the topologies of the end-ring can be different on both sides of the machine, both corresponding views are displayed (see illustration below).
Figure 5. End-ring design area – Displaying of the three design views - Front view (1), Connection side view (2) and Opposite connection side view (3)
Subsections
Design
For more details, please refer to Design.
Impedance
For more details, please refer to Impedance.
X-Factor
For more details, please refer to X-Factor.
Operating
For more details, please refer to Operating.
