I - Ψ - N
Positioning and objective
The aim of the test “Mechanics – NVH – Working point – I-Ψ-N” is to perform NVH analysis of the machine when operating at the targeted working point defined with the following inputs values I,Ψ,N (Magnitude of current, Control angle, Speed).
Figure 1. “Working point – Sine wave – Motor – I, Ψ, N” illustration
This test gives data allowing NVH prediction in early electromagnetic and design stage.
The modal analysis of the stator mechanical structure, the radiated sound power and the magnetic forces applied on teeth are computed and displayed.
This test helps to answer the following question: Could the machine have any risks in connection with NVH? Yes / No.
The following table helps to classify the test “Mechanics – NVH – Working point – I-Ψ-N”.
Table 1. Positioning of the test “Performance mapping – Sine wave – Motor – Efficiency map”
Family Mechanics - NVH
Package Working point
Convention Motor
Test I-Ψ-N
Subsections
For more details, please refer to Inputs.
Thermal
For more details, please refer to Thermal.
Mechanics
For more details, please refer to Mechanics.
