Thermal
One button gives access to the thermal settings:
  • External fluid temperature
  • Cooling circuit fluid temperature
Note: The external fluid temperature corresponds to the temperature of the fluid surrounding the machine. It is also considered the temperature at the “infinite” for the computation of radiation from the frame to the infinite.
Note: The cooling circuit fluid temperature exists only when a cooling circuit has been added by the user in the design environment. In this case, this input describes its fluid inlet temperature.
