Table
List of working points
Table 1. List of working points to be defined
1 Click on the button “Set values” of the field “ U, f, N description” to define the working points in a dialog box. Refer to the next illustration which shows how to fill the working point table.
1.1 Dialog box opened after having clicked on the button “Set values” in the field “Cycle description”
1.2 Browse the folder to select an Excel file to define the working points to be considered
1.3 Button to refresh the table data when the considered Excel file has been modified
1.4 Fields to be filled with data to describe the list of working points to be considered
1.5 Excel file template to define the list of working points
