Standard inputs
DC voltage
Voltage provided by the external DC source.
Speed
The imposed “Speed” (Speed) of the machine must be set.
Advanced inputs
Circuit resistance
Parasitic resistance of the circuit connecting the DC voltage source with the DC machine.
Circuit inductance
Parasitic inductance of the circuit connecting the DC voltage source with the DC machine.
No. comp. / revolution
The user input “No. comp. / revolution” (Number of computations per revolution) influences the accuracy of results and the computation time.
The default value is equal to 50. The default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 13.
No. computed revolutions
The user input “No. computed revolutions” (Number of computer revolutions) influences the computation time, it may also have an important impact to assure the steady state has been stablished (imperative condition to achieve accurate results).
The default value is 2. The minimum allowed value is 2 and the maximum value is equal to 4.
Mesh order
To get the results, the original computation is performed using a Finite Element Modeling.
By default, a second order mesh is used.
Airgap mesh coefficient
The advanced user input “Airgap mesh coefficient” is a coefficient which adjusts the size of mesh elements inside the airgap. When the value of “Airgap mesh coefficient” decreases, the mesh elements get smaller, leading to a higher mesh density inside the airgap and increasing the computation accuracy.
The imposed Mesh Point (size of mesh elements touching points of the geometry), inside the Flux® software, is described as:
MeshPoint = (airgap) x (airgap mesh coefficient)
0.05 giving a very high mesh density and 2 giving a very coarse mesh density.
Caution:
Be aware, a very high mesh density does not always mean a better result quality. However, this always leads to a huge number of nodes in the corresponding finite element model. So, it means a need for huge numerical memory and increases the computation time considerably.
