The purpose of the Lookup Table wizard and map block is to allow you to encapsulate nonlinear behaviors through direct measurements. You can, for example, use laboratory data or a manufacturer’s component performance data directly in a simulation.
Embed supports 1D, 2D, and 3D look-up tables. You can set up the look-up tables manually in a map block or you can use the Lookup Table wizard, which automates the set-up process.
You can find map block examples under Examples > Blocks > Nonlinear.
