2026
Reference guides are available for functions and commands supported by OML, Tcl, and Python.
OpenMatrix is a mathematical scripting language.
Errors and warning messages are both output in the console (or the Command Window in GUI mode) of Compose.
See the Try/Catch description in the Flow of Control and Looping section.
Composeの新規機能や特徴について紹介します。
Composeと、その言語サポートおよびシステム要件について説明します。
Composeのチュートリアルとそれに付随する各種のモデルファイル例は、このソフトウェアの基本機能を理解するうえで効果的です。
Composeで利用できる機能や特徴について紹介します。
Literals are items that are constant throughout the life of the application. Literals include numeric, imaginary, characters, strings, logicals, and Other (NaN/Inf).
Data types are items that are constant throughout the life of the application and are built into the OpenMatrix language.
Strings are arrays of characters.
OML language scripts manipulate data through variables. Variables are referred to by their name (alphanumeric) and can be created (assigned) and deleted as described in this section.
Indexing is used to retrieve one or more specific values out of a collection.
Operators are used to combine operands.
Each operator in this section is explained with the operations of scalars, vectors, and matrices that are allowed for said operator.
Statements are made of expressions, which may be simple or complex.
Loops are used to perform the same set of statements multiple times.
There are two types of workspaces: Local and Global.
Functions are packets of statements that can be used repeatedly.
OpenMatrix statements persist in .oml files.
This section describes files that can be manipulated by the OpenMatrix Language.
There are two types of errors: parse-time, and run-time.
Warning messages are similar to error messages in that they are output into the console or command window.
Create 2D and 3D plots and control their style and appearance.
Objects in OML are defined using the classdef keyword. This creates a blueprint for an object but does not actually create (instantiate) anything.
The Reference Guide contains documentation for all functions supported in the OpenMatrix language.
Extension Managerで利用可能なオプションライブラリのヘルプを表示します。
よくある質問リスト
