LAW19 and LAW58 for Fabric
Radioss has two material laws for modeling fabrics LAW19 and LAW58. LAW19 is an elastic orthotropic material and must be used with /PROP/TYPE9. LAW58 is hyperelastic anisotropic fabric material and must be used with /PROP/TYPE16.
Coupling between warp and weft directions could be defined in this material law to reproduce physical interaction between fibers. Both material laws are often used for airbag modeling.
- Nonlinear function (fct_IDi) curve to define the warp, weft and shear behavior
- Young's modulus, soften coefficient B, straightening
strain Si and fiber bending modulus reduction factor
Flexi
In warp and weft direction:
σii=Eiεii−(Biεii2)2 (i=1,2) when dσdε>0
σii=maxεii(Eiεii−(Biεii2)2) (i=1,2) when dσdε≤0
For in-plane shear in initial state, use G0 . Once α (angle between wrap and weft) reaches αT (shear lock angle), then use GT to describe the strengthening.
τ=G0tan(α)−τ0 if α≤αT
τ=GT1+tan2(αT)tan(α)+(G0−GT1+tan2(αT))tan(αT)−τ0 if α>αTFigure 1.
In LAW58, use Flexi to describe this behavior:
