*INITIAL_VELOCITY
LS-DYNA Input Interface KeywordDefines initial velocity of a node set.
(1) (2) (3) (4) (5) (6) (7) (8)
*INITIAL_VELOCITY
set_ID Exset_ID IRIGID CID
VX VY VZ VXR VYR VZR
Read if Exset_ID > 0
Blank
Definition
set_ID Node set identifier.
= 0
The velocity is applied to all nodes
> 0
The velocity is applied to the nodes in the node set identifier
(Integer)
Exset_ID Node set identifier of nodes that are exempted from the initial velocities (VX, VY, VZ, VXR, VYR, VZR).
(Integer)
IRIGID Option to overwrite velocities defined in *PART_INERTIA or *CONSTRAINED_NODAL_RIGID_BODY_INERTIA.
= 0
No overwrite.
= -1 or -2
Overwrite.
(Integer)
CID Coordinate system identifier.
(Integer)
VX, VY, VZ Translational nodal velocity components.
(Real)
[ms]
VXR, VYR, VZR Rotational nodal velocity components.
(Real)
[rads]
  1. This keyword maps to /INIVEL.
