*INITIAL_FOAM_REFERENCE_GEOMETRY
LS-DYNA Input Interface KeywordDefines the reference state for elements belonging to a part, using given nodal coordinates.
(1) (2) (3) (4) (5) (6) (7) (8)
*INITIAL_FOAM_REFERENCE_GEOMETRY_{OPTION}
NSID CID
If OPTION = RAMP
Nitrs
Add a line for each node
node_ID X Y Z
Definition
OPTION
RAMP
Define the number of steps from reference to initial state.
Nitrs Number of steps from reference to initial state.
Default = 100 (Integer)
node_ID Node identifier.
(Integer)
X X coordinate.
(Real)
[m]
Y Y coordinate.
(Real)
[m]
Z Z coordinate.
(Real)
[m]
  1. This keyword maps to /XREF.
