/INIBRI/STRESS
Block Format Keyword Describes the initial state (full stress for the brick, not for each integration points and in local reference system) for a brick.
/INIBRI/STRESS/unit_ID
bric_IDst σ   x σ   y σ   z
σ   x y σ   y z σ   x z
Definition
unit_ID Unit Identifier
(Integer, maximum 10 digits)
bric_IDst Stress element identifier
(Integer)
σ   x Stress
(Real)
σ   y Stress
(Real)
σ   z Stress
(Real)
σ   x   y Shear stress
(Real)
σ   y   z Shear stress
(Real)
σ   x   z Shear stress
(Real)
  1. The initial state for brick may be defined by more than one block.
  2. Using /INIBRI/STRSESS you are assuming there is no density of the deformed elements. Before the first cycle Radioss will check consistency of the input stress tensor with material data (stiffness and density).
    D = s 11 + s 22 + s 33 3 − B u l k ⋅ ( 1 − ρ ρ 0 ) = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maalaaabaGaam4CamaaBaaaleaacaaIXaGaaGymaaqabaGccqGH RaWkcaWGZbWaaSbaaSqaaiaaikdacaaIYaaabeaakiabgUcaRiaado hadaWgaaWcbaGaaG4maiaaiodaaeqaaaGcbaGaaG4maaaacqGHsisl caWGcbGaamyDaiaadYgacaWGRbGaeyyXIC9aaeWaaeaacaaIXaGaey OeI0YaaSaaaeaacqaHbpGCaeaacqaHbpGCdaWgaaWcbaGaaGimaaqa baaaaaGccaGLOaGaayzkaaGaeyypa0JaaGimaaaa@5293@
    Where,
    ρ 0
    Density defined in the Starter file
    ρ
    Density in the state file
    If the stress is not fulfilled, then Radioss will correct the diagonal entry of the stress tensor:
    s i i n e w = s i i i n i t i a l − D
