/INIBRI/SCALE_YLD
Block Format Keyword This option is used to set a scale factor for yield stress per element for solids.
/INIBRI/SCALE_YLD/unit_ID | |||||||||
brick_ID | nptr | npts | nptt | nlay |
Repeat the next line for each integration point and layer
Alpha_lkji |
Definition
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
brick_ID | Element
identifier (Integer) |
nptr | Number of integration
points in direction r (Integer) |
npts | Number of integration
points in direction s (Integer) |
nptt | Number of integration
points in direction t (Integer) |
nlay | Number of layers.
1 (Integer) |
Alpha_lkji | Yield stress scale
factor of integration point lkji with:
(Real) |
In this example use:
/PROP/SOLID
Isolid=16 with Inpts=322 => must set nptr=3; npts=2;
nptt=2 (then i=3; j=2;
k=2 in Alpha_lkji).
Then the yield stress scale factor Alpha_lkji is below, and are
totally
3×2×2=12
Alpha_lkji values.
#- 1. LOCAL_UNIT_SYSTEm:
/UNIT/2
unit for PROP
# MUNIT LUNIT TUNIT
Mg mm s
#- 2. GEOMETRICAL SETS:
/PROP/SOLID/1/2
Solid part -1
# Isolid Ismstr Icpre Itetra10 Inpts Itetra4 Iframe dn
16 0 0 0 322 0 0 0
# q_a q_b h LAMBDA_V MU_V
0 0 0 0 0
# dt_min istrain IHKT
0 0 0
/INIBRI/SCALE_YLD
# brick_ID nptr npts nptt nlay
1 3 2 2 1
# scale_yld
1.20
.80
1.20
1.20
.80
1.20
1.20
.80
1.20
1.20
.80
1.20
#enddata
/END
- nlay is used for Thick shells /PROP/TYPE22. The number of integrations points in the corresponding direction needs to be set to 1. For the other solid elements, nlay needs to be set to 1.
- The number of integration points must be set according to the property type of the element and its formulation flag.
- The scale factor for solids may be defined by more than one block.
- This option is available for /MAT/LAW36. The card is ignored for the other materials.
