/GRTRIA/PART
Block Format Keyword Group of triangles (/TRIA) is built according to PART identifiers which are provided.
Enter selected items numbers (any number may be input, 10 per Line)
/GRTRIA/PART/grtria_ID/unit_ID
grtria_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
Definition
grtria_ID Group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grtria_title Group title
item_ID1, item_ID2,..., item_IDn List of parts identifiers
(Integer)
  1. The 2D solid triangles groups cannot contain 2D solid quadrangles (use /GRQUAD instead).
  2. If item_ID is a negative number, the item number is deleted from the group.
