/GRTRIA/BOX or /GRTRIA/BOX2
Block Format Keyword Defines a group based on triangles (/TRIA) which are inside the box.
Only one box_ID is allowed:
/GRTRIA/BOX/grtria_ID/unit_ID or /GRTRIA/BOX2/grtria_ID/unit_ID
grtria_title
box_ID
Definition
grtria_ID Group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grtria_title Group title
box_ID Box identifier, which is defined in Boxes
  1. The 2D solid triangle groups cannot contain quad elements (use /GRQUAD instead).
  2. If type is BOX, all elements having all nodes inside the box or on its surface are selected.
    If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
