/DRAPE
Block Format Keyword This option is used to read fiber orientation changes and thinning for each of the plies which are usually the result of a manufacturing process simulation.
Different angle change, and thinning can be defined for each slice of the element set.
/DRAPE/drape_ID
drape_title
For each element set, add:
Entity Entity_ID Thinning_1 θ drape_1
If there is more than one slice for the element set, add:
Thinning_i θ drape_i
Definition
drape_ID Drape identifier.
(Integer, maximum 10 digits)
drape_title Drape title.
Entity Must be left justified.
SHELL
The entity is a 4 nodes shell element.
SH3N
The entity is a 3 nodes shell element.
GRSHEL
The entity is a group of 4 nodes shell element.
GRSH3N
The entity is a group of 3 nodes shell element.
(Integer)
Entity_ID Entity identifier.
(Integer)
Thinning_1 Ply thinning factor for the first slice.
(Real)
θ drape_1 Ply orientation change for the first slice.
(Real)
[deg]
Thinning_i Ply thinning factor for the slice i.
(Real)
θ drape_i Ply orientation change for the slice i.
(Real)
[deg]
  1. The drape is used in /PLY and /PROP/PLY (TYPE19) to take into account the manufacturing process on the orientation and thickness of each slice of the elements. See Example (Substack with /DRAPE) in /STACK. There is a minimum of 1 slice per element.
  2. The number of integration points defined in /PLY and /PROP/PLY (TYPE19) is ignored and replaced by the number of slices defined in /DRAPE.
  3. The orthotropy angle is defined as follows from the reference vector (Anisotrophy in Layer (Ply)) defined in the stack:
    ϕ=ϕs+ϕi+Δϕ+θdrape
    Where,
    ϕi
    is defined per ply in stack
    ϕs
    is defined on the element
    is defined on the ply
    ϕ d r a p e
    is defined in the drape table
  4. The ply thickness ti of the element as defined in the ply is scaled using the thinning factor Thinning for each slice.
