*CONTROL_TIMESTEP
LS-DYNA Input Interface KeywordDefines time step control conditions.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTROL_TIMESTEP
TSSFAC DT2MS
Definition
TSSFAC Scaling coefficient for the time step.
(Real)
DT2MS
< 0
Minimum constant nodal time step.
(Real)
[s]
  1. This keyword maps to /DT/NODA/CST.
  2. Resulting starting timestep will be = to TSSFAC * DT2MS * -1.
