*CONTROL_HOURGLASS
LS-DYNA Input Interface KeywordDefine default solid and hourglass formulation for 8-node solid elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTROL_HOURGLASS
IHG QH
Definition
IHG 8-node solid and hourglass formulation.
= 0 (Default)
The solid formulation is defined in *SECTION_SOLID.
= 5
Standard 8-node solid element, one integration point. Elastic stiffness hourglass formulation with orthogonal and rigid deformation modes compensation (Belytschko).
(Real)
QH Hourglass coefficient.
Default = 0.1 (Real)
  1. This keyword maps to /PROP/TYPE14 (SOLID).
  2. IHG=5 is available only for the isotropic materials.
