Run Model Quality Checks on Selected Entities
Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
From the Validate ribbon, click the Model tool.
Figure 1. - On the guide bar, use the first selector to choose the entities to be validated.
- Optional:
Click
to run checks on all entities in the model.
You can also choose to run just Error checks or Warning checks by selecting the appropriate option. -
Click Run Checks.
The entities that do not meet the solver requirements are flagged under the respective checks in the Model Checker.
- If any of the checks have auto-correction enabled on them, click Auto Correct to run the correction.
