Find Connectivity
Check the connectivity between two or more components.
Certain types of connections can be included or excluded while checking for
connectivity.
Restriction: Only available in the LS-DYNA and Radioss user
profiles.
From the Validate ribbon, click the Connectivity
tool.
Figure 1. The Find Connectivity browser opens. -
In the Entity Editor, enable the type(s) of
connectivity to include in the check.
By default, all types of connectivity are enabled except Connectors.
Use the Select Entities selector to select two or more components to check the
connectivity between.
Connectivity check works on all the selected components regardless of its display state. Connectivity due to mass elements are completely excluded when checking connectivity.
Click Check.
If two or more parts are connected, the number of connected parts are displayed in the browser. Expand the folders to see individual components. If the parts are free, the free part is displayed separately.
Connectivity Types
Radioss
- Recursive
- If checked, will isolate and find recursive connectivity.
- Physical connectivity
- Checks for node to node connectivity (for 1D, 2D and 3D).
- RBE2
- Checks for RBE2 connectivity.
- Rigids
- Checks for RBODY connectivity.
- Interface2
- Checks for contacts with INTER/TYPE2.
- Connectors
- Checks for FE realized connections with connectors.
- Rigid Links
- Checks for RLINK connectivity.
- RBE3
- Checks for RBE32 connectivity.
- Joints
- Checks for CYLJOINT connectivity.
LS-DYNA
- Constrained Extra Nodes
- Checks for connections using constrained extra nodes and extra noded joints.
- *CONSTRAINED_EXTRA_NODES
- Constrained Rigid Bodies
- Checks for connections using constrained rigid bodies.
- *CONSTRAINED_RIGID_BODIES
- Constrained Groups
- *CONSTRAINED_TIE-BREAK
- *CONSTRAINED_TIED_NODES_FAILURE
- Contact Groups
- *CONTACT_SPOTWELD
- Connectors
- Rigid Links
- *CONSTRAINED_NODAL_RIGID_BODY
- *CONSTRAINED_NODE_SET_ID
- *CONSTRAINED_GENERALIZED_WELD
- *CONSTRAINED_SHELL_TO_SOLID
- Welds
- *CONSTRAINED_SPOTWELD
- RBE3
- *CONSTRAINED_INTERPOLATION
- Joints
- Checks for connections with Joints
- Slipring and Retractor
- Checks for connections with sliprings and Retractor
- *ELEMENT_SEATBELT_SLIPRING
- *ELEMENT_SEATBELT_RETRACTOR
