Quadrotor Control Co-Simulation with Twin Activate
In this tutorial, you will learn how to use MotionSolve and Twin Activate in a co-simulation to control a Quadrotor model.
A quadrotor model is a multirotor helicopter that uses 2 sets of identical fixed pitched propellers (2 clockwise and 2 counter-clockwise) to control lift and torque.
Control of vehicle motion is achieved by altering the rotation rate of one or more rotor discs, thereby changing its torque load and thrust or lift characteristics.
In MotionView you will create the quadrotor frame with 4 superblades and add the rotors motions. A set of forces will be used to represent the wind disturbance.
Twin Activate, through co-simulation with MotionSolve, will implement a controller to impose altitude and direction in quadrotor trying to compensate against the wind effect.
Twin Activate is a software solution for multi-disciplinary, dynamic system modeling and simulation. The software is especially useful for signal-processing and controller design that requires both continuous-time and discrete-time components.
A co-simulation enables MotionSolve and Twin Activate models to communicate with each other during simulation. An ideal use case for co-simulation is the development of a control system for a multibody dynamics model.
Before you begin, copy the file(s) used in this tutorial to your working directory.
Review the Model
  1. Start a new MotionView session.
  2. Select File Open model to load the Quadrotor_start.mdl file from your working directory.
  3. Review the model.
    The Quadrotor model has 9 bodies, one frame called vehicle, 4 propellers and 4 rotors. Associated with them are their respective graphics.
    To connect these 9 bodies there are 4 fixed joints connecting the rotors with the vehicle and 4 revolute joints connecting the propellers with the rotors.
Specify the Propeller's Motion
  1. Select the Model Ribbon and click Motions , to display the Motions guide bar.
    Figure 1. Motions Guide Bar
  2. Click on the ellipsis next to the Joint collector to access the advanced selections dialog. Select Propeller_Left and click OK.
    Figure 2. Select a Joint Dialog
  3. Click on the Create icon in the Motions microdialog to add the motion.
  4. In the Entity Editor, for Label and Variable, enter Prop_Left_Rotation and mot_Prop_Left_Rotation respectively.
    Figure 3. Motion's Label and Variable Name in the Entity Editor
  5. In the General section, change the Property to Velocity and click on on the guide bar to finish editing.
    Observe that the guide bar remains open to create new motions.
    Figure 4. Motion's Property Type Set to Velocity
  6. Repeat the steps 1-5 to create motion in the other propellers. When complete, click on the Cancel icon to exit the Motions guide bar.
    Label Variable On Joint Property
    Prop_Right_Rotation mot_Prop_Right_Rotation Propeller_Right Velocity
    Prop_Front_Rotation mot_Prop_Front_Rotation Propeller_Front Velocity
    Prop_Rear_Rotation mot_Prop_Rear_Rotation Propeller_Rear Velocity
    In a quadrotor, the velocity of the propeller is defined by the controller of pitch and roll of the vehicle.
    To define the velocity value of each propeller motion, create three solver variables in the next step that are used further in the co-simulation.
Specify the Velocity of the Propellers
  1. Before you can specify the velocity, you must first create the solver variables.
    1. On the Model tab, click on the Variables icon to display the Add SolverVariable dialog.
    2. For Label, enter Throttle_Command.
    3. For Variable, enter sv_Throttle_Command and click OK.
      Figure 5. Add Solver Variable Dialog
      Figure 6. Solver Variable's Entity Editor
    4. Repeat the steps a-c to create the Pitch and Roll solver variables.
      Label
      Variable
      Roll_Command
      sv_Roll_Command
      Pitch_Command
      sv_Pitch_Command
  2. Now you can update the propeller motion velocity.
    1. From the Model Browser, browse to the Motions folder and select the Prop_Left_Rotation motion.
    2. From the Motions Entity Editor, go to the Properties section.
    3. From the Properties section, change Type to Expression and enter:
      `VARVAL({sv_Throttle_Command.idstring})+VARVAL({sv_Roll_Command.idstring})`
      Make sure to hit enter to complete the selection.
      Figure 7. Prop_Left_Rotation Motion Expression
      Note: You may need to perform a check model (Ribbon > Home Group > Check) to get the expression evaluated.
    4. Repeat the steps above for Propeller Right, Front and Rear, following the table entries below:
      Motion
      Expression
      Prop_Right_Rotation
      `VARVAL({sv_Throttle_Command.idstring})-VARVAL({sv_Roll_Command.idstring})`
      Prop_Front_Rotation
      `-VARVAL({sv_Throttle_Command.idstring}) -VARVAL({sv_Pitch_Command.idstring})`
      Prop_Rear_Rotation
      `-VARVAL({sv_Throttle_Command.idstring})+ VARVAL({sv_Pitch_Command.idstring})`
      Note: The lateral propellers (left and right) control the Roll of the vehicle and the vertical propellers control the Pitch. The signal difference in the expressions determine the rotation direction of the quadrotor.
      Figure 8. Propellers' Thrusts To Control the Quadrotor's Motion
Add Wind Disturbance Forces
To represent the wind effect and thrust of the quadrotor, a set of forces and moments must be defined.
The wind disturbance is represented as a combination of torques in the X and Y axle applied at the vehicle center.
The thrust of each propeller is represented as a Z force following this equation:
Fz=Tf*ωz2
Where,
Fz = Thrust force
Tf = Thrust factor (Defined considering the propeller geometry, air density, m and spin area. For this analysis Tf= 2.1998e-5).
ωz = Propeller Angular velocity
  1. Create the wind disturbance force.
    1. From the Model ribbon, click on the Forces icon to open the Forces guide bar.
      Figure 9. Wind Disturbance Force Guide Bar
    2. Set Force to Action only Force and Property to Rotational.
    3. For the Body 1 collector, select Vehicle and for the Origin collector, select Pivot.
    4. Select Global frame as the Reference Marker.
      Note: Global frame can be picked by clicking in the empty space in the modeling window.
    5. Click on the Create icon to generate the Force.
    6. In the Entity Editor, enter Wind_Disturbance for Label and frc_Wind_Disturbance for Varname.
      Figure 10. Forces Entity Editor
    7. From the Rot Properties tab, set tx and ty to 0.5 and click on to exit editing the current Force.
      Figure 11. Rotational Properties Section Parameters
  2. Create the thrust force.
    1. Click on the Forces icon to open the Forces guide bar.
    3. For the Body 1 collector, select Rotor_Left and for the Origin collector, select Left_Motor_Center.
    4. Select Left_Rotor as the Reference Marker.
      Figure 12. Thrust Force Guide Bar
    5. In the Entity Editor, enter Thrust_Left for Label and frc_Thrust_Left for Varname.
      Figure 13. Thrust Force Entity Editor
    6. From the Trans Properties tab, change fz to Expression and enter the expression: `2.1998e-5*ABS({j_Propeller_Left.WZ})^2`.
      Figure 14. Trans Properties Parameters
    7. Repeat the steps to create the thrust force for the right, front, and rear rotors.
      Thrust Right
      Label
      Thrust_Right
      Variable
      frc_Thrust_Right
      Body 1
      Rotor_Right
      Origin
      Right_Motor_Center
      Ref Marker
      Right_Rotor
      fz Expression
      `2.1998e-5*ABS({j_Propeller_Right.WZ})^2`
      Figure 15. Right Rotor's Entity Editor Parameters
      Thrust Front
      Label
      Thrust_Front
      Variable
      frc_Thrust_Front
      Body
      Rotor_Front
      Point
      Front_Motor_Center
      Ref Marker
      Front_Rotor
      fz Expression
      `2.1998e-5*ABS({j_Propeller_Front.WZ})^2`
      Figure 16. Front Rotor's Entity Editor Parameters
      Thrust Rear
      Label
      Thrust_Rear
      Variable
      frc_Thrust_Rear
      Body
      Rotor_Rear
      Point
      Rear_Motor_Center
      Ref Marker
      Rear_Rotor
      fz Expression
      `2.1998e-5*ABS({j_Propeller_Rear.WZ})^2`
      Figure 17. Rear Rotor's Entity Editor Parameters
  3. To save your model, click Save As and save it with the name Quadrotor_tutorial.mdl.
Create Control Inputs and Plant Outputs
To modify the MBS model to work in a Co-Simulation Mode you need to add solver arrays and solver variables entities in MotionView model. The solver variables contain the individual plant input and output values. The solver arrays define the plant input and output to communicate with Twin Activate.
  1. Adding solver variables.
    1. The individual plant input solver variables were already defined with the propellers motion in Specify the Velocity of the Propellers. They are Throttle_Command, Roll_Command and Pitch_Command.
  2. Next, you will define the individual plant output values, which are Altitude, Roll Angle, Pitch Angle, X position, Y position, X velocity and Y velocity.
    1. In the Model ribbon, click on the Variables icon in the References group, to open the Add SolverVariable dialog and add the following solver variables:
      Label Variable Expression
      Altitude sv_Altitude
      `DZ({m_Vehicle.idstring})`
      Roll_Angle sv_Roll_Angle
      `AY({m_Vehicle.idstring})`
      Pitch_Angle sv_Pitch_Angle
      `AX({m_Vehicle.idstring})`
      PosX sv_PosX
      `DX({m_Vehicle.idstring})`
      PosY sv_PosY
      `DY({m_Vehicle.idstring})`
      VX sv_VX
      `VX({m_Vehicle.idstring})`
      VY sv_VY
      `VY({m_Vehicle.idstring})`
      Note: Remember to set the Type in the SolverVariable Properties tab to Expression.
  3. Create two solver arrays, ControlInput and PlantOutput, to communicate with Twin Activate.
    1. In the Model ribbon → References group, click on the arrow to expand additional options. Click on Arrays to open the Add SolverArray dialog.
      Figure 18. Solver Arrays Icon
      Tip: You can use the search field located in the top right corner of the window to search for any functionality, for example Array in this case.
    2. For Label, enter ControlInput.
    3. For Varname, enter sa_ControlInput and click OK.
    4. From the Properties section, change the Array type to Plant Input.
      Figure 19. Solver Array Type set to Plant Input
    5. Click on Variables in the Entity Editor, to invoke the Select a Solver dialog.
    6. Select the ‘+’ symbol next to the model to access a list of Model’s Solver Variables.
    7. Select Roll_Command for SolverVariable 0, Throttle_Command for SolverVariable 1 and Pitch_Command for SolverVariable 2 in this order. To add entities, first click on the Solver Variable on the left and then on the plus sign on the right. Finally, click the Apply button to complete the Solver Array creation.
      Figure 20. Plant Input Variables
    8. Click on Arrays to display the Add SolverArray dialog.
    9. For Label, enter PlantOutput.
    10. For Variable, enter sa_PlantOutput and click OK.
    11. From the Properties tab, change the Array type to Plant Output.
      Figure 21. Solver Array Type set to Plant Input
    12. Select the Roll_Angle, Altitude, Pitch_Angle, PosX, PosY, VX, and VY variables in this order and click Apply.
      Figure 22. Plant Output Variables
  4. Save your model .
Run the MBS Model in MotionSolve for Verification
  1. From the Analyze ribbon, click on Analysis settings next to Run, to open the Run Motion Analysis dialog.
    1. Select the Run offline option.
    2. Rename the Run name input to Quadrotor_tutorial.
    3. Select an Output directory folder, where the results will be save and click on the Run button.
    Figure 23. Run Motion Analysis Window
  2. Click Results to animate the simulation results and confirm that the model works as intended before continuing to the next step.
    Note: The controller is not yet connected to the model, so the input force and torque are zero.
Connect MotionSolve with Twin Activate
  1. From the All Programs menu, launch Twin Activate.
  2. From the menu bar, select File > Open model to load the Quadrotor_Control_Start .scm file from your working directory.
    The system has 3 sections of control: Altitude of the quadrotor, X position and Y position. The X and Y position control is defined by a target path, for this model it is a slope of 0.025.
    Figure 24. System’s Three Control Sections
    These three sections of controls defined by seven PIDs are the plant input for the MBS model. In MotionView, it's defined as Roll_Command, Throttle_Command and Pitch_Command.
    The plant output, Roll_Angle, Altitude, Pitch_Angle, PosX, PosY, VX, and VY, are input for the PID controls.
    For example, in the X position target control, you will see three inputs which come from the plant output (PosX, VX, and Roll Angle).
    Figure 25. X Position Target Control Section
  4. To enable co-simulation between Twin Activate and MotionSolve, from Twin Activate, select File > Preferences > Paths. In the dialog that is displayed, define the MotionSolve and MotionView license paths.
    Figure 26. Twin Activate Preferences
  5. From the Palette Browser, select Palettes > Twin Activate > CoSimulation, and drag-and-drop the MotionSolve block into the current diagram and connect the blocks.
    Figure 27. MotionSolve Block Inclusion
  6. From the diagram, double-click the MotionSolve block. From the dialog that is displayed, define the following block properties:
    1. XML or MDL input filename: Browse the path to your MotionView .mdl model or MotionSolve .xml file (Quadrotor_tutorial.mdl or Quadrotor_tutorial.xml) by clicking the file selector.
      Note: Twin Activate allows you to define either MDL or XML as the input for co-simulation with MotionSolve. When you choose MDL as the input file name, MDL is converted to XML on run time so you may notice a delay as the co-simulation is beginning.
    2. MRF output filename: Specify the path for the output MRF file (Quadrotor_tutorial.mrf). Use the forward slash, /, in your path definition.
    3. Direct feed through: Clear (default) the check box. If the object is selected and the simulation runs and encounters an algebraic loop, the option should be cleared to break the algebraic loop.
    The following parameters are populated automatically after you load the input model, *.mdl or *.xml:
    • Inputs Row Size: The value 3 indicates that three signals are supplied from Twin Activate to the MotionSolve model. These signals correspond to the solver array PlantInput, with variables Roll_Command, Throttle_Command and Pitch_Command.
    • Outputs Row Size: The value 7 indicates that the MotionSolve model is sending out seven signals from one port, which is why the Demux block is added to separate the signals. The signals correspond to the solver array PlantOutput with variables Roll_Angle, Altitude, Pitch_Angle, PosX, PosY, VX and VY.
      Figure 28. MotionSolve Loaded Model’s Parameters Ribbon
      Figure 29. MotionSolve Loaded Model’s Advanced Ribbon
    Co-simulation with Twin Activate can be done in two ways:
    Local co-simulation
    In this case, both MotionSolve and Twin Activate are installed on the same machine. You do not need any additional setup and the fields “MotionSolve server IP address” and “MotionSolve server port number” can be left at their default values as shown in the figure above. Upon starting the co-simulation from Twin Activate, the connection between the two solvers is made automatically, based on the paths specified in Step 4.
    Remote co-simulation between Twin Activate and MotionSolve
    In this case, MotionSolve and Twin Activate can be located on different machines that are accessible over the network. The following section describes how remote co-simulation can be accomplished.
    It will be assumed that Twin Activate is installed on Machine A and MotionSolve is installed on Machine B, where Machine A and B are not the same. Such a scenario is useful when the MotionSolve model is located on Machine B and transferring the model to Machine A to do a local co-simulation is not feasible.
    Note: For successful co-simulation, a valid installation of MotionSolve is still needed on Machine A.
    Machine A
    1. Complete Step 4 (setting up the paths) on Machine A. These should point to a valid install of MotionSolve on Machine A.
    2. Within the MSPlant block, specify the exact name (without the path) of the MotionSolve model that is located on Machine B.
    3. Within the MSPlant block, specify the IP address and port number for Machine B using the fields “MotionSolve server IP address” and “MotionSolve server port number”
    4. Click OK.
    Machine B
    1. Setup the following MotionSolve environment variables within a command prompt window.
      • NUSOL_DLL_DIR: points to the location of the MotionSolve binaries (typically <altair>/hwsolvers/motionsolve/bin/win64).
      • PATH: Append the path specified for NUSOL_DLL_DIR to the system path.
      • RADFLEX_PATH: points to the location of the MotionSolve license libraries (typically <altair>/hwsolvers/common/bin/win64).
      • Navigate to the directory where the MotionSolve model resides.
      • Invoke the MotionSolve server command “msdaemon” by typing in “msdaemon” in the command prompt. This starts the MotionSolve server in “listening” mode.
    To co-simulate, continue following the rest of this tutorial.
  7. Click and drag to connect the output of the block Mux to Control Input of the MS Plant. Similarly, connect the Plant Output end of the MS Plant to the input end of Dmux. All required blocks are now present and connected in the modeling window.
    Figure 30. Twin Activate Co-simulation Model Diagram
  8. From the ribbon's Simulate tool group, select the Setup tool. From the Simulation Parameters dialog, in the Final Time field, enter 12 so that your simulation runs for twelve seconds.
    Figure 31. Simulation Parameters
    Note: Since Twin Activate is the main, or calling, solver in this co-simulation scenario, if the simulation end time in Twin Activate is different than the MotionSolve simulation end time, the MotionSolve simulation end time will be modified at run time to match the end time specified in the Twin Activate dialog above.
  9. From the ribbon, click Run .
    The Scope blocks in the model generate the following plots, which illustrate the altitude, roll, pitch, x position, y position, and the path.
    Figure 32. Altitude
    Figure 33. Roll
    Figure 34. Pitch
    Figure 35. X Position
    Figure 36. Y Position
    Figure 37. X Velocity
    Figure 38. Y Velocity
    Figure 39. XY Path
  10. Launch HyperView and animate the Quadrotor_tutorial.h3d file to see the quadrotor behavior.
    Figure 40. Load H3D File in HyperView
    Figure 41.
  11. Before exiting the applications, save your work in Twin Activate as quadrotor_complete.scm.
