General Constraint
Class GeneralConstraint()
GeneralConstraint(parent='MODEL', name='GeneralConstraint_n',
label='GeneralConstraint_n', active=True, expr='``', use_reaction_marker=False,
reaction_marker='Global_Frame')
Creates a general constraint.
Keyword Arguments
Argument Data Type Description Default
name String The variable name. GeneralConstraint_n, for next available integer n.
label String The descriptive label. GeneralConstraint_n, for next available integer n.
parent Object The parent. MODEL
active Boolean Used to activate or deactivate this entity. True
expr Function The expression value. ''
use_reaction_marker Bool Use reaction marker when True for SolverMode ADAMS. False
reaction_marker Marker Marker reference when use_reaction_marker is True for SolverMode ADAMS. Global_Frame
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
