Field
Class Field()
Field(parent='MODEL', name='Field_n', label='Field_n', active=True,
b1=None, b2=None, k=36 * [0], c=36 * [0], f=6 * [0], length=6 * [0],
damping_type='CRATIO', cratio=0, origin=None, ornt_meth='TWOAXES')
Creates a field.
Keyword Arguments
Argument Data Type Description Default
name String The variable name. Field_n, for next available integer n.
label String The descriptive label. Field_n, for next available integer n.
parent Object The parent. MODEL
active Boolean Used to activate or deactivate this entity. True
b1 Body The first body constrained by the field. None
b2 Body The second body constrained by the field. None
k NumericVector Stiffness values of the 6x6 stiffness matrix. 36*[0]
c NumericVector The damping coefficients of the 6x6 damping matrix. 36*[0]
f NumericVector The force values for the six components (3 forces, 3 torques) at the corresponding lengths (length1 : length6). Zero force would mean a free length at the given lengths. 6*[0]
length NumericVector The reference lengths between the i marker and the j marker. 6*[0]
damping_type Enum Use CRATIO to apply damping as a percentage of stiffness, or use MATRIX to supply a 6x6 damping matrix. One of MATRIX or CRATIO. CRATIO
cratio Double Damping as a percentage of stiffness, applied to each stiffness. 0
origin Reference The location. None
ornt_meth Enum The orientation method. One of TWOAXES, ONEAXIS or ANGLES. TWOAXES
ornt_dir1 Enum The direction used to orient axis 1. One of X, Y or Z. Z
align_meth1 MultiRef Alignment method for axis 1. One of Point, Vector or DxDyDz. DxDyDz
align_pt1 Reference The point when align_meth1 is Point. None
align_vec1 Reference The point reference when align_meth1 is Point. None
ornt_dir2 Enum The direction used to orient axis 2. One of X, Y or Z. X
align_meth2 MultiRef Alignment method for axis 1. One of Point, Vector or DxDyDz. DxDyDz
align_pt2 Reference The point when align_meth2 is Point. None
align_vec2 Reference The point reference when align_meth2 is Point. None
e1 Double The e1 Euler angle (z:x':z'') in radians with respect to rm. 0
e2 Double The e2 Euler angle (z:x':z'') in radians with respect to rm. 0
e3 Double The e3 Euler angle (z:x':z'') in radians with respect to rm. 0
rm Reference The reference marker when ornt_meth is ANGLES. Global_Frame
x1 Double The direction cosine x1 for axis 1. 0
y1 Double The direction cosine y1 for axis 1. 0
z1 Double The direction cosine z1 for axis 1. 1
x2 Double The direction cosine x2 for axis 2. 1
y2 Double The direction cosine y2 for axis 2. 0
z2 Double The direction cosine z2 for axis 2. 0
user Bool Use user defined properties, if true. False
usr_sub Function The expression passed to the user dll. When using solver expressions, Templex syntax (within ) is used and all variables are enclosed in braces {} and the rest is treated as literal. 'USER()'
local_funcname String The function/subroutine name. 'MOTSUB'
use_local_dll Bool Uses a local function instead of default if True. False
local_dll File The path of the local dll which has the local_funcname. ''
local_func_type Enum The type of the user subroutine. one of DLL, PYTHON or MATLAB. 'DLL'
Instances
Instance Type Description
xaxis Vector The vector in x direction of orientation.
yaxis Vector The vector in y direction of orientation.
zaxis Vector The vector in z direction of orientation.
Examples
Create and modify attributes of a Field.
   >>> # Import mview module
   >>> from hw import mview
   >>> #Create a field
   >>> f = mview.Field()
   >>> b_1 = mview.Body()
   >>> b_2 = mview.Body()
   >>> p1 = mview.Point()
   >>> f.b1 = b_1
   >>> f.b2 = b_2
   >>> f.origin = p1
   >>> f.b1.name
   'Body_1'
   >>> f.b2.name
   'Body_2'
   >>> f.damping_type
   'CRATIO'
   >>> # Change the damping value
   >>> f.cratio = 0.4
   >>> f.cratio
   0.4
   >>> # Change the force values for the six components
   >>> f.f = [1,2,3,4,5,6]
   >>> f.f
   [1.0, 2.0, 3.0, 4.0, 5.0, 6.0]
