Creates CERIG elements for the head and the LINK10 element for body.
There are two individual CERIG elements at the head of the connection, one to connect to
the inner row of nodes, the other to connect to the washer layer nodes. The connector
location can either be on the edge of the hole, center of the hole, midpoint in between
the two holes or on the second row of nodes which form the washer layer. Property and
material cards are created for the LINK10 element.
