Creates RBE2 (Nastran/OptiStruct) or KINCOUP (Abaqus) elements
for the head and the body.
Restriction: Available in Abaqus, Nastran, and OptiStruct.
There are two individual RBE2/KINCOUP elements at the head of the connection, one to
connect to the inner row of nodes, the other to connect to the washer layer nodes. The
RBE2/KINCOUP head element that connects to the washer layer nodes only connects to every
other node on the washer layer. The connector location can either be on the edge of the
hole, center of the hole, midpoint in between the two holes or on the second row of
nodes which form the washer layer.
