Create and review pressure loads on 1D elements that are fully or partially
loaded.
From the menu bar, click Aerospace > Loads/BCs > PLOAD1 Create and Review.
This tool can also be used to edit or review the PLOAD1 cards imported from a solved
Nastran or OptiStruct
data file.
Inputs are 1D elements and the start/finish local parametric values and the pressure
at those points (start and end pressures).
Load type indicates the direction (FX, FY, FZ, and so on) and the Scale factor
determines if it is based on parametric (fraction-FR) or based on actual length
(LE).
Figure 1. . A partially loaded 1D beam. The load is applied between 0.3 and 0.6 local
u values.
