Create an assembly structure from a .csv file
definition.
You can create an assembly structure (product structure) similar to a PDM system
using the Assembly Browser or Part Browser
(Module Browser). Both tools are provided using the same .csv
file format described below. You can import this file and the tool automatically
creates the product structure in the database. You can drag and drop components into
the assembly tree to organize the models in a similar manner to CAD or PDM product
structures.
Figure 1. A .csv File Format for the Product Structure
Definition
When you import this .csv file as an assembly or part you will
get the following organization in the Assembly Browser (assembly
csv) or Part Browser (part csv).
Figure 2. A Product Structure is Created in the Assembly Browser
Organize Aerospace Components
Use this tool to split a monolithic FE model (imported from solver data files) into
suitable HyperMesh components. These components are then
manually moved into assembly product structures to create a real world aerospace
model. Two useful methods can be used to split the monolithic FE model into
components. One involves using the coordinate system and the other uses ID
ranges.
Using the coordinate system
Shell and beam models can be split using a local coordinate system.
Figure 3. A Single Component Model
Click Assembly > Organize Aero Components Using
Cord-System.
Select the local system and the elements to be organized. It is
required that you create empty components where these elements
are to be split using the coordinate system. The elements are
separated based on the system directions (within the Angle
Deviation tolerance) and are moved to the empty components.
Figure 4. The Model is Split into Components using the Local
System Direction
Using ID ranges
Aerospace users typically assign ID ranges to specific components. Using
these definitions from a .csv file, the elements
are automatically separated into component names defined in the
.csv file.
Figure 5. ID Range .csv File with Component Names
Figure 6. Based on ID Ranges, Elements are Separated into Components
