Tsai-Wu Criterion
The Tsai-Wu theory defines the ply failure index as below:
Findex=(1XT−1XC)σ1+(1YT−1YC)σ2+σ21XTXC+σ22YTYC+τ212S2+2F12σ1σ2
Where:
- Xt,Xc are the maximum allowable stresses in the 1-direction in tension and compression,
- Yt,Yc are the maximum allowable stresses in the 2-direction in tension and compression,
- S is the allowable in-plane shear stress
- F12 is a factor to be determined experimentally
TsaiWuFT(tensor,xt,xc,yt,yc,s,f12,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
Arguments
- tensor
- Stress table
- xt
- Allowable tensile stress in ply material direction 1
- xc
- Allowable compressive stress in ply material direction 1
- yt
- Allowable tensile stress in ply material direction 2
- yc
- Allowable compressive stress in ply material direction 2
- f12
- F12 experimental factor
- s
- Allowable in-plane shear stress
- sets
- Set table (D=NULL)
- plies
- Ply table (D=NULL)
- elems
- Element table (D)
- parts
- Part table (D)
- props
- Property table (D)
- pool_name
- Pool name (D=@current_pool)
- layer_index
- Layer index (D=@current_slice_index)
- opt_str
- This is an optional argument, which can passed if needed (D=option).
Tsai-Wu Reserve Factor
Considering the above expression for the Failure Index if we set:
A=σ21XTXC+σ22YTYC+τ212S2+2F12σ1σ2
B=(1XT−1XC)σ1+(1YT−1YC)σ2
C
Being a given factor of safety, then the reserve factor formula can be evaluated as below:
TsaiWuRF(tensor,xt,xc,yt,yc,s,f12,FoS,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
Arguments
- tensor
- Stress table
- xt
- xc
- yt
- yc
- f12
- FoS
- Factor of Safety (D=1.0)
- s
- sets
- plies
- elems
- Element table (D)
- parts
- Part table (D)
- props
- pool_name
- layer_index
- opt_str
