COSIN/io 2D Road Type: flatbelt
COSIN/road searches for the data block $flatbelt, and reads:
Name of input variable | Unit | Meaning |
v | m/s | Rotation speed of belt surface (be sure to choose rolling_speed = 0 in data block $sources. Otherwise, the wheel moves away from the belt). |
number_cleats | - | Number of extra cleats on belt (number_cleats = 0 allowed). |
cleat_height | mm | Height of extra cleats. |
cleat_length | mm | Length of cleat, measured in circumferential direction of drum. |
cleat_bevel_edge_length | mm | Length of bevel edge of cleat, measured in circumferential direction of drum. Bevel edge has 45deg slope. |
mu_factor_cleat | - | Friction modification factor on cleats. |
acceleration_time | s | Optional time span at beginning of simulation during which the belt is accelerated to nominal speed. |
