COSIN/io 2D Road Type: hydropulse_harmonic
COSIN/road searches for the data block $hydropulse_harmonic, and
reads:
Name of input variable | Unit | Meaning |
frequency_flfrequency_frfrequency_rlfrequency_rr | Hz | Hydro-pulse excitation frequencies at front left / front right / rear left / rear right wheel. |
amplitude_flamplitude_framplitude_rlamplitude_rr | mm | Hydro-pulse excitation amplitudes at front left / front right / rear left / rear right wheel. Set amplitude to zero, if the respective wheel is not to be excited. |
phase_flphase_frphase_rlphase_rr | deg | Hydro-pulse phase angles at front left / front right / rear left / rear right wheel. |
