Generating Position and Gradients for Loaded Configuration
- Start with the NLFE Body in a No-Load configuration and apply Force/Motion to load the NLFE Body as needed.
Include the MotionSolve Save command to save the states of the model into an
XML file (herein referred as “saved state XML”) after the Simulate command. A
Template that writes into the solver command section can be used in MotionView.
Figure 1. -
Click on Default Analysis in the Model Browser and then select the Scripted
Simulation check box from the Entity Editor - Analysis.
Figure 2. -
Solve the model. Select the Run offline option in the
Run settings and click the Run button.
Figure 3. -
Once the run is complete.
Once the CSV file is saved, import it into the Position &
Gradients table available in the NLFE Body Connectivity section
of the Entity Editor.
Figure 5. Figure 6.
