Materials
Use the tool to view, add, and edit the material properties that are used for NLFE bodies.
Create and Edit Materials
From the Model menu, select from the drop-down menu.
The Material Properties dialog opens.
- Select an elasticity type from the left-most drop-down menu.
Select a material from the Material list and review its properties.
CAUTION: For your convenience, a set of materials are provided by default. The values of the properties provided are generic in nature, and might not be appropriate for the actual problem or material you intend to use with it. It is advised these materials be used with caution and that you obtain more accurate material properties.
- Optional:
Edit the material's elastic strain limit by entering a value in the
corresponding field.
Note: For NLFE bodies, MotionSolve will provide warning whenever the strain in the body crosses this specified limit. You can also disable a material's elastic strain limit but deactivating the check box next to the field.
Add a new material property.
- Select the desired elasticity type.
- Click the Add button to bring up the Add a Material Property dialog.
- Specify a label for the material property.
- Specify a variable name for the material property.
- Select a preexisting material to use as a source for the new material's values or select New.
Tip: Delete any material property that was added by selecting that property and clicking Delete. -
Edit the material property.
- Click Close to exit the dialog.
Hyper Elastic Materials Overview
For hyper elastic materials, different constitutive material models are supported, such as: Neo-Hookean (both compressible and incompressible), Mooney-Rivlin, and Yeoh models that are used to model a hyper elastic NLFE Body.
Hyper elastic materials can undergo large deformations with a non-linear stress strain relationship.
The constitutive models for hyper elastic materials are characterized using the strain energy density function.
Type | Equation | Description |
Neo-Hookean Compressible | U=μ2(I1−3)−μlnJ+λ2(lnJ)2 | U - Strain Energy density function μ - Shear modulus I1−rTxrx+rTyry+rTzrz - rx, ry, and rz are the gradients of NLFE grids λ=2μv1−2v , is called the 2nd Lame's constant, v is the Poisson's ratio J=det(J)=rTx(ry×rz) |
Neo-Hookean Incompressible | U=μ2(ˉI1−3)+k2(J−1)2 |
ˉI1=J−23I1
k=2μ(1+v)3(1−2v) , bulk modulus |
Mooney-Rivlin | U=μ10(ˉI−13)+μ01(ˉI2−3)+k2(J−1)2 | μ01 and μ10 are material constants ˉI2=J−43I2 ˉI2=12((tr(C))2−(tr(C2))) , where C is the Cauchy-Green deformation tensor C=JTJ J=[rxryrz] rxryrz are the gradient vectors |
Yeoh | U=C10(ˉI1−3)+C20(ˉI1−3)2+C30(ˉI1−3)3+k2(J−1)2 | C10, C20, and C30 are material constants |
The material constants for these models have to be derived through testing, such as: uniaxial, bending, and shear tests.
