poINote GetAttachmentTypeList
Gets the list of entity types to which a note can be attached.
poINote_handle GetAttachmentTypeList
HyperView Tcl Query
This command returns a list of valid entity types to which a note can be attached. Current valid entity types include: window, coord, node, element, part, and system.
To retrieve the entity type list for a note whose ID is
2:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetNoteHandle note_handle 2;
set att_types [note_handle GetAttachmentTypeList]
hwi CloseStack
None.
