poIMeasure GetTypeList
Gets the possible measure types.
poIMeasure_handle GetTypeList
HyperView Tcl Query
This command returns the possible measure types. Options include: Position
{Relative Displacement} {Distance Between} {Incremental Distance} {Minimum
Distance} {Relative Angle} {Angle Between} {Incremental Angle} {Nodal Contour} {Elemental
Contour} {Component Contour} {Node Path} {Yaw Pitch Roll} {Circle
Radius}.
Note: This example assumes that the d3plot file
(demos/mv_hv_hg/animation/dyna/bumper) has been loaded.
variable t [expr rand()];
hwi GetActiveClientHandle cl$t
set measid [cl$t AddMeasure "Circle Radius"]
cl$t GetMeasureHandle meas$t $measid
meas$t AddNode 516
meas$t AddNode 226
meas$t AddNode 242
cl$t Draw
meas$t GetType
meas$t GetTypeList
meas$t ReleaseHandle
cl$t ReleaseHandle
None.
