Spline Stiffness Model
The spline stiffness formulation interpolates a Force versus Deflection table using Akima’s cubic interpolation method. For values of deflection outside the supplied range, the force is linearly extrapolated using the slope at the corresponding end-point. For each direction employing the spline-stiffness formulation, you must supply a Force versus Deflection table in the property file. The force is calculated as follows:
Fi=Akispl(qi,table)
Where:
qi is the displacement of Body-I relative to Body-J in the ith direction after offset, scaling and coupling effects have been considered.
table is the force-deflection table specified in the [SPLINE_STIFFNESS_xx] block in the .gbs file.
