Altair Compute Console starts with the main window (Figure 1). To run the job with any solver, select
the Input file(s) for the run using the File Browser button and
ACC automatically selects the appropriate solver based on the filename extension of
that file. The choice of the solver is indicated using icons in the titlebar, and in
the bottom left corner of the form. Some solver codes allow a file with non-standard
extension (or even arbitrary extension) – in that case it is necessary to specify
the solver (use -solver option) and Available Options form will not
be available.
Figure 1. Altair Compute Console
The required options for the run can be entered into the Options field or selected
from the Available Options window accessed by clicking .
The checkboxes below the Options field are available to avoid having to type specific
options.
Use SMP: -nt 2
Automatically adds option allowing an SMP run: -nt N,
where the value for N can be selected in the
Preferences editor.
Use MPI options
Automatically creates an SMPD run: usually this requires several
options, so these options can be prepared in the Preferences editor in
advance and used when appropriate.
Use solver control
(same as -screen option) Uses Solver Control form which
provides additional interactive control for OptiStruct and Radioss solvers (STOP, PAUSE, and so on). It is recommended to leave this box
selected for all solver runs.
Schedule delay
Allows you to delay all jobs in the queue (which are not currently
running) up to a predefined time (one week maximum).
Each selection is only effective if appropriate, the options are not used if they are
not germane to the selected solver. The selections can also be overridden when such
options are entered manually into the Options field (presumably with different
values); however when any SPMD related option is used in the Options field, then
selected options via Use MPI options from the Edit > Preferences path will be skipped entirely. The effect of these selectable options
is not shown in the Options field, nor is it stored in the history or queue manager,
but they are appended to the command line at the moment when the solver is actually
started.
Click Run to start the solver and opens a separate progress
window called Altair Compute Console Solver View.
