The Graph button inside the Summary window allows you to open a simple X-Y plot and
browse the dynamic convergence of various variables displayed in the Summary
window.
Figure 1. Optimization Summary Graph Button
The Graph function is available only when convergence data are available, and it
provides a graphical way to visualize the convergence process.
Hovering over any point on the graph displays the iteration number and the tracked
variable value and possibly grid/element identification number if applicable.
Four buttons at the left bottom corner of graph window enable you to:
(Lin) or (Log) switch
between Linear and Log-Linear plot. In Log mode the sign of traced variable
is removed (all values are treated as non-negative)
(<) and (>) zoom plot on
the left or right range of values
