Define Pulse Mathematically
Define a time pulse using an analytical equation.
Figure 1. Define a time signal using an analytical equation.
Time axis unit
Specify the unit to be used for the time axis.
Total signal duration ( sd )
The total length of the signal in the specified units.
f(t)
Analytical equation describing the input pulse, where t can be used as the input time variable.
Number of samples
The number of samples taken from the signal’s analytical equation.
