Math Functions in POSTFEKO
View the list of supported math functions.
| Shortcut Key | Description |
| ABS | Absolute value |
| ARCCOS | Arccosine (radians) |
| ARCCOT | Arccotangent (radians) |
| ARCSIN | Arcsine (radians) |
| ARCTAN | Arctangent (radians) |
| ATAN2 |
Arctangent of Y/X in the range -PI to PI Syntax: |
| CEIL | Smallest integer value that is equal or greater than the argument |
| COS | Cosine (radians) |
| COSH | Hyperbolic cosine (radians) |
| COT | Cotangent (Radians) |
| DD |
Polynomial derivative of a function Syntax: Example: |
| DEG | Convert radians to degrees |
| EXP | Exponential function |
| FFT |
Fast Fourier transforms of a real function. The bandwidth can be provided as additional argument. Syntax: Example: |
| FLOOR | Largest integer value that is equal to or smaller than the argument |
| FMOD |
Resulting reminder of a/b. Syntax: |
| IFFT |
Inverse Fast Fourier transform of a complex function. The resulting range can be specified as additional argument. Syntax: Example: |
| IMAG | Determines the imaginary component |
| LN |
Computes the natural logarithm Syntax: Example: |
| LOG | Computes logarithm base 10 |
| MAX |
Returns the largest of the two arguments Syntax: |
| MIN |
Returns the smallest of the two arguments Syntax: |
| NORM |
Normalise a function Syntax: Example: |
| ONES |
Creates a list of points with a constant value 1 Syntax: |
| PEAK |
Returns the peak value in the given range of values Syntax: Example: |
| PHASE | Determines the phase |
| RAD | Convert degrees to radians |
| RAMP |
Ramp function Syntax: Example: |
| REAL | Determines the real component |
| SELF | A reference to the current trace |
| SIN | Sine (Radians) |
| SINH | Hyperbolic sine (Radians) |
| SQRT | Square root |
| STEP |
Step function Syntax: |
| TAN | Tangent (Radians) |
| TANH | Hyperbolic tangent (radians) |
| ZEROS |
Creates a list of points with a constant value of 0 Syntax: |
Predefined Variables
| Variable | Description |
| i | Imaginary unit |
| j | Imaginary unit |
| c0 | The speed of light in free space in m/sec. |
| eps0 | The permittivity of free space in F/m. |
| mu0 | The permeability of free space in H/m. |
| pi | The mathematical constant (Ludolph’s number). |
| zf0 | The characteristic impedance of free space in Ohm. |
