To run the MIT from HyperGraph for the first time, follow steps 1-2. After the initial setup, you can run the
                    MIT from the HyperGraph
                toolbar as you see in Step 3.
                From the File menu in HyperGraph, select .
The Preferences dialog appears.
                From the Registered Preferences list, select Model Identification
                        Tool, and then click Load.
The MIT appears on the HyperGraph menu bar.
                From this point on, you have access to the MIT from
                    the HyperGraph menu bar. To run the MIT, select .
The
MIT opens to the Select Data tab.
Note: While running the
MIT, if pending job(s)
                        from past
MIT sessions are detected, a dialog
                        prompts you with the following options:
                            - Abort: Discard pending job(s) from a previous HyperGraph session.
                            - Retry: Load pending job(s) from a previous HyperGraph session and restart the Fit or
                                Analyze operations that were suspended.
                            - Ignore: Ignore the pending jobs.
